Posting this for a friend, lemme know if you have any questions
It's a '99 FRC Z51 - 82K Miles on body.
Fully built Katech 402 aluminum block - 5K Miles on motor.
Lingenfelter 6.0 Heads
Custom Blower Cam
Callies Crank
Callies Rods
Custom JE Pistons - 9.5:1 compresion ratio
LG Long Tubes
Borla Stinger Exhaust
B&M Shifter
D1SC Stage II Kit - Twin Intercooled - 12# of boost.
8 Rib pulley kit
Custom Fuel system - Dual 255lph pumps
60# injectors
Fast Fuel Rails with -8 lines
Custom 2 Bar tune set to 91 octane
OEM Z06 Rims - 275s up front, 315 Drag Radials out back
Power Slot slotted and dimpled rotors all arround
Spec 5 Clutch
Stock 3.42 gearing
Clean Title
Asking $50K - Reasonable offers or trades + cash will be considered
E-Bay Listing
This car is my DD as most people know so it's set up to sign and drive as is with over 700rwhp on 91 octane. I get 16mpg around town and 25mpg on the highway with this setup as well. This car has been only been modded by AZ Power and Sound from day 1 and has no problems or drivability issues. I can have it setup for race fuel if you want a 950rwhp car as well as this motor will take anything and then some.
Bottom line is this project is finished as I do not want to cage the car for track use. I would like to start a new project and need the room.
Pics can be seen here: LS1TECH - For Sale: 700+ rwhp Vette
Custom Blower Cam
Callies Crank
Callies Rods
LG Long Tubes
B&M Shifter
8 Rib pulley kit
60# injectors
Spec 5 Clutch
Stock 3.42 gearing
Clean Title
E-Bay Listing
