I put on new front timing cover and cam from postons.I go to install the cam sensor and it won't go.I think it is the cover because i already sent one cover back because one oil hole was bored through housing.then when i got this one I had to spend a lot of time to set up the pump...real poor quality part.after i got the pump assem. I tried the cam sensor to check allignment and all seemed o.k.After final assem.the bore is to close to cam and can't get it in.Either the cam gear is to big or the cover is sh#@!Any sugestions and who sells a good cover?
