Lets hope not. Have you actually tried them all (no bench racing)? I have had Hypers in the past and have a set going in my new engine and they work fine! Mile High runs em, Banning runs em (my old motor), Lee Thompson runs em and many others flawless! Forged are better for a more race than street car and the stock cast pistons have been proven time and time again to hold up awesome even down in the 9's. Nothing like a tight fitting cast or hyper piston to aid in ring control. Go with what you can afford and what works for your intended power level. If you mess up in your tune it will not matter if you have Titanium pistons.Originally posted by 86brick
Like Steve mentioned Forged, nothing else compares!!! The Hyperpathetics and cast pistons are junk and you may have to rebuild it again if you go the cheap route so you can spend a little more now and do it right or spend a lot more later to fix it. Your choice???
The higher silicon content of the hypers actually raise the melting temp of the piston so your friend would have really have tore up a piston with less silicon content. Using higher dollar pistons is no band-aid for tuning inadequicies. Go tell the Supra guys their factory stock hypers suck as they make 800 HP dyno pulls on them Back to bench racingOriginally posted by 86brick
Well I myself have never and will never have the Hyper-pathetics (pun intended) cause there was a guy that tried them down here and his car had a stock turbo, V4 intercooler, 009's, and was a very mild low 12 maybe high 11 second combo and he melted www.harpersracing.com
Let me get my hip-waders out here If your friend melted a piston it leaned out, period. They don't just melt! It takes mucho heat to do it so yes his tune was not right (be it bad injector, etc..). If you plan on getting as high in the HP as Dutt then by all means go forged but for 400-450 HP the hypers work fine. If you plan on racing all the time go forged. I don't mind the opinions but prefer someone who has "actually used" something than an opinion of I heard it from Billy Bob Buckwheat. Do some of what you opinionate on then give us your .002.Originally posted by 86brick
Intercooler, there was no tuning "inadequicies" as you like to say. He was running 20lbs of boost and the only detonation that ever occured was on the shift (transitional knock) which is very common, but maybe it's not for an expert like yourself Bottom line is the hypers are not even close to the quality of a forged piston whether you want to believe it or not and as far as the Supra guys are concerned I've seen many down here and most guys trying to achieve 800hp will go with some JE light weight forged pistons as I know of a couple that have had motors built. It's like what Steve said before about some guys having good luck with N.A. cranks..... spend a couple of hundred now or thousands later like some have before!!! Oh yeah, maybe somebody should tell Duttweiler to start using hypers cause the Supra guys make 800hp with them
