Something doesn't seem right here. When I made 730rwhp I was running 118mph in the 1/8th with a 1.50 sixty foot. If your running 24.5psi or more your mph should be a lot higher then that even if the et doesn't match. Your et matches your dyno numbers at 14psi. Even at your altitude your car should be going at least 140+mph. Not posting to disrespect you, but your down a considerable amount of power based on your dyno numbers.
Here is a calculator to show you what your car would do at proper elevation, which is
10.309 @ 131.085 MPH based on your timeslip
http://www.dragtimes.com/da-density-altitude-calculator.php?elevationcorrect=3775&et=10.506&mph=128.66&correctetmph=Correct ET and MPH
Here is a calculator to show you what kind of rear wheel power you were making on that pass
http://www.tciauto.com/tc/racing-calculators/
It's a shame you didn't get any data from that pass, it could explain better what is going on. Good luck with it, Hopefully you can unlock the Genie in the bottle.
