PhilM said:How straight does the glass come out? Gel coat? Also, are they offered in cowl?
Phil
HOFSGNX said:Dusty, yes I just bought it, but my body guy already has about $200 into getting it to look right (of which POSTON has credited me $150) and about $100 into the front latch assembly to work and level with the front header piece. The thing is all painted and looks good now except for getting the front latch assembly to work and level with the front header piece.
Who did you talk to at POSTON? It is probably too late to ship it back at this point - what do you think? I was hoping someone had some experience here and could walk me through to get the front latch assembly to work on the POSTON hood. Any thoughts?
HighPSI said:Oh, sorry I forgot to answer two questions....
No, they do not come with a "cow scoop"
As far as how much weight difference, I believe they were 27 lbs difference when we weighed them, but not totally positive. Maybe one of my customers can tell you exactly how much they lost on weight (other customer...Jason of RJC and Dick Kereny). Holly Hartline
HighPSI said:........... We would recommend hood pins in the front for any cars running 140+ mph. If you wish to put your name on our order list for Indy, call Holly @ 321-722-1563.
HOFSGNX said:Anybody else have problems with the POSTON hood as it sounds like I should go for a full refund on the one that was shipped to me.
My body guy had to:
1.) build up the drivers side front edge as it was out of square
2.) cut down the passenger side underside front because it hits the radiator support
3.) completely redo the latch area because it is not built up enough in one area and has to be repositioned in another in order to get the front latch assembly to work.
I will call them tomorrow. POSTON is good about standing behind there products so I do not think it will be a problem. Their stuff has always been good to me otherwise.
Any other input before I call would be greatly appreciated. Thanks.
HighPSI said:They are black gel coated and pretty much ready to paint. Cal's on his car was lightly wet sanded (not block sanded), then painted. If you are looking for show quality, I would recommend the paint shop block sand it before painted, but otherwise, they paint up pretty nice. The same hood is on several customer cars (ie...Louie Lopez, Tony Gomes, Dave Fiscus), Dusty just purchased one at BG. You can look at a painted one on Cal's car on our website. Thanks, Holly Hartline
nordy racer said:
you have to get different shocks.. they are only a couple bucks..
