my car is an 87gn, 57mm turbo 42lb injectors, front mount intercooler, 2800 stall
1) how can i be sure that my existing setup has any knock? Keep the scanmaster on O2 setting and watch the "0.0" on the right for knock retard? how reliable is the caspers knock gauge? mine seems to light up once in a while, although I haven't compared the readings to the scanmaster output. ( ihave heard these gauges are finicky).
2) I am currently running a caspers chip (told by previous owner) I was told this chip has the wheel adjustable (with 7 different setting). Where exacly is this wheel located so that I can see what setting its currently set on? Is it on the chip itself? Also from my online research it looks like the caspers chip is not capable of small adjustments like the turbo tweak is (you can only keep it on one of the 7 pre-set settings).
3) how much power would i be leaving on the table with this old caspers chip?
4) is it worth it to upgrade to the turbo tweak 6.1 so WOT can be controlled with a wideband gauge? I would have to also upgrade injectors as turbo tweak v6.1 needs minimum 50lb injectors
sorry for the newb questions. i apreciate the feedback. my goals for the car are just a reliable fun street car.
