See pictures below. I am beginning to slowly part out my car. Parts have all bee used less then 500 miles. Call me if ou have questions 859-312-3184 or message me. Paypal accepted, but you pay the fees.
Fast Fuel XFI includes:
Fast XFI ECU w/o2
Buick Adapter Harness 36"
Internal Data logger
XFI Thumbwheel
3 Bar Map Sensor
Wideband
O2 Bung
Fuel/Oil Loggin harness with sensors and fittings
Conservative tune loaded.
$2000 Delivered - This is a $400 savings off a new set up wtih these items
Limit Engineering GTQ 70MM Turbo
3 bolt
4inch inlet
2.5 inch out
Journal bearing
1 HD Actuator
1 LD Actuator
4 -AN Feed Oil Line Included
Feed and Drain Fittings included
Perfect condition
$1000 Delivered - $400 less than a new one
Delphi 96 Lb Injectors - 6
Excellent condition
$300 Delivered - $100 less than new
Champion Fuel Rails - NON STOCK FUEL REGULATOR version
Excellent condition
Bolts included
$200 Delivered - $50 less than new
Champion 1" Plenum Spacer
Gaskets and Bolts
$75 Delivered
This is only the beginning of my parts, more to come after these.
Fast XFI ECU w/o2
XFI Thumbwheel
3 Bar Map Sensor
Wideband
O2 Bung
3 bolt
4inch inlet
2.5 inch out
Journal bearing
1 HD Actuator
1 LD Actuator
Perfect condition
Excellent condition
Excellent condition
Bolts included
Gaskets and Bolts
$75 Delivered
