i'm having trouble with the amount of voltage that my ecu is seeing... just idling or driving normally the FAST voltage sensor reads about 13.2V... the power distribution block in the engine compartment reads about 13.6V... that's not that big of a deal, the problem comes when i'm under full load... the FAST voltage sensor drops down to around 11.5V... meanwhile, a voltmeter on the power distribution block (measured while on the dyno) still reads 13.4-13.5V... my limited electronics knowledge tells me that my ECU is not being fed with thick enough power and ground wires... I'm running low impedance 75lb/hr injectors, anyone know what the current draw would be at 80% duty cycle? i am using a fast track performance splice-in harness that reuses some of the factory wiring... i suspecct that i need to run new dedicated (and thicker gauge) power and ground wires directly to the ecu... any suggestions on a) what size wire and b) which pins need this supply? i know there is a BATT+, BATT- and switched 12V... are there any others that are voltage sensistive? which pin gets the main power to actually run the injectors and what not?
thanks!
thanks!
