v6turbojunkie
- Mar 14, 2004
Ok, I installed the WB02 sensor and then ran the jumper harness(#30-C018) to the cockpit. Then I'm supposed to install the seven wires coming from the ecm into a connector and plug it into the harness. Problem is the connector is wrong. It is the little square looking ports and I need blades. Should I solder the connection and skip the connector?
John
John
