Ecugn coil control
Chris Brooks
Installing the 599a coil on my hot air t and I'm at the spot where I plug in the yellow wire from the coil harness into the egr connector but its a male to male connection. Male from my factory harness and male from the coil harness. Anyone got an idea on which wire from the factory harness i need to connect? I will just depin it from the connector. Thanks for the help guys
On the vehicle side, the brown EGR wire is the one to connect to the yellow wire.
The 84/85 connector is different and not directly compatible, as you've found.
Eric
