Abe, you're not bothering me. The tune should be very close when switching between the two boxes. On your 6 cylinder box, even though it is called a B2B, it is actually firing the injectors sequentially, albeit out of phase. This is not the case with B2B boxes for 4 & 8 cylinder applications. This is why Buick B2B boxes run larger injectors better than the other applications that are cutting the p/w in half and firing twice as much. As for the ESC, etc.. it varies from box to box. There was only so many things the old FAST boxes could do. Most of the ones I tuned, had fan and fuel pump control, and IAC control. They didn't usually have ESC or NOS control. On my own SEFI box, I had "O2 ignore" which would turn the WBO2 correction off when the ESC wire was grounded. I used this when I was on the 2 step.
