G GSX-PKV Active Member Joined Oct 5, 2001 Aug 11, 2012 #1 I noticed that the fan for AC and the heater stopped working. What should I look for to correct the problem. Thanks! Paul
chopped39 Well-Known Member Joined Aug 30, 2004 Aug 19, 2012 #3 Make sure it has a good connection at blower motor under hood. does it work on high speed?
C charlief1 RIP Charlie! Joined Sep 20, 2007 Aug 19, 2012 #4 Have you used a test light to see if it's getting power?
G GSX-PKV Active Member Joined Oct 5, 2001 Aug 19, 2012 #5 The fan does not work at any speed. The connections under the hood seem solid and I'll check with a tester to see if it is getting power. Thanks.
G GSX-PKV Active Member Joined Oct 5, 2001 Aug 19, 2012 #6 Checked everything under the hood and it all checked out. Just for the heck of it - using the barbarian mechanic school fix - I hit the top of the fan housing a couple times with my fist and the fan stated working Hopefully it will keep working.
