HEATSEEKER
Member!
- Jan 16, 2006
bbbbaad said:the knock is still there when I rap the engine, but not when I bring up revs slowly. This is in neutral or running down the road.
Exact the same for me... :frown:
Pronto said:Octain boost is poop. Get 100 ul or make some homebrew and test it after you run down that stuff.
Wells said:All octane booster contains something called MTBN, or MBNT, or something like that, which is basically a lead substitute, and it will fry your 02 sensor and plug your cat. Keep in mind that when the octane booster can says "This product will add 10 points to your octane level, a point is only a tenth of an octane, so most cans/bottles/comntainers of octane booster will raise your octane only a octane or two at most. 100 octane unleaded worked for me, both as a test, and for fueling. My kr went totally away, indicating to me that it was real kr, and was not doing the motor any good.
