I am in the troubleshooting stages of trying to find the reason for Turbolink showing timing retard while accelerating under no load, in neutral. I can rev the engine slowly to 4200 RPM and get no indication of retard in timing, but get about 30-40 degrees retard when I rev quickly to that range. If I rev quickly and hold it there, the retard goes away after a couple of frames.
I have read so many posts on this subject, compiled a listing of what people say to check and have been eliminating one at a time, testing to see if it clears each time. I am still getting the same indication and these are all of the things I have done to try and fix it so far:
- Replaced ignition module and coil tower – Done with Delco parts
- Replaced spark plugs – Done RJ-42TS @.025 gap
- Replaced plug wires – Done with Delco wires
- Checked down pipe for clearance- Clear from hitting anything while accelerating in neutral but has dent in it from hitting frame, obviously from engine rolling under load and hitting the frame.
- Checked headers and crossover pipes for cracks/leaks – Donut gaskets leaking mildly, tightened all connections on flange except for the PITA connection on passenger side.
- Checked belt tensioner – Hitting nothing, has adequate tension on belt
- Checked torque converter cover for tightness – One bolt broken, removed cover all together and left it off.
- Check motor mounts – Driver side allows engine to rock under acceleration but not broken, new at about 1500 miles ago
It started raining so I needed to stop for the night. Tomorrow I will continue to search for more problems. This is a list of things that I am going to investigate next:
- Check knock sensor for tightness
- Replace knock sensor
- Check torque converter tightness to flywheel
- Check fuel pressure at WOT, currently set at 40 PSI with hose on but can't be affecting knock in neutral, can it?
- Back down the boost, currently 15 psi but doesn't seem to be able to affect this in neutral...not developing any boost
- Check fuel filter
- Replace PCV
- Check harmonic balancer is tight
Something has to be causing this. It isn't happening at constant throttle no matter what speed I hold but does retard the timing when I rev the engine quickly.
Jack Merkel rebuilt the engine 1500 miles ago. The tranny was rebuilt a few weeks ago at a local shop. I have no reference as to whether this was occurring before either of the builds occurred. I only know it is here now.
I am accepting most any challenges on this. I doubt that I will disassemble the engine to find something wrong, I would rather leave the false knock going if that is necessary.
I am thinking that I am going to replace the knock sensor first thing in the morning and see if that fixes it first and go from there.
Thanks for listening and hopefully for a response.
Andy
- Check fuel filter
- Replace PCV
Andy
