For folks familiar with the stock ECM's programming: What values for max/attack/decay does the factory ECM use for electronic spark control / knock retard? I need to plug the following parameters into my XFI setup.
Respective values of 15 (max), 3 (attack), 0.5 (decay) seem to be common and that's what I've been using, but wanted a few extra cents. The attack rate of 3 degrees per 0.1 second of knock seems high to me given the values that I used to see in directscan with the factory ECM (KR would move in tenths at times...). Thoughts?
Thanks,
Scott
- Max ESC retard (in degrees)
- ESC attack rate
- ESC decay rate
Thanks,
Scott
1. Max. ESC Retard (*)This is the maximum amount of timing retard allowed if the knock sensor is activated. Even if knock is still detected once this limit is reached, no more timing will be pulled out.
2. ESC Attack Rate (*) This parameter defines the number of degrees to retard the timing every .1 second when the knock sensor is activated. In other words, this parameter is used to set how fast the timing will be pulled out when knock is detected. In the above form, with the attack rate set at 5, the timing would be lowered 5 degrees every .1 second until the knock sensor deactivated, or until the maximum ESC retard limit was reached.
3. ESC Decay Rate (*) This parameter defines the number of degrees to remove the timing retard every .1 second after the knock sensor becomes inactive. In other words, after timing is pulled out due to knock detection, this parameter is used to set how fast the timing will be added back in. If the decay rate is set to 0.50 as above, the timing will come back in at .5 degree per .1 second (or 5 degrees per second) until the ESC retard has reached zero.
