meanchicken
gallo vicioso
- Oct 6, 2007
I gotta get this done.
I'm sporting around at 200-220 on hot days...after a load inducing run it spikes up higher and then cools back down to 200-220.
My tranny lines are probably not a problem. I already have an external transcooler mounted down where the SLIC intercooler scoop used to be, and it uses flexible lines to run too/from the transmision cooler tank and then to the transmission on my stock radiator, so as long as the fittings on the radiator are the same size as the F-body rad, this should be a non issue.
So is it posible to do it in two steps (swap Radiator first and then do the fan later without pulling the radiator back out)?
