8 87BUICKGNTURBO Member Joined Jun 3, 2014 Jun 8, 2014 #1 Is it normal for the engine to knock when turbo boost kicks in? If not, how do I correct?
L larry33kc Well-Known Member Joined Aug 19, 2001 Jun 8, 2014 #2 The knocking you hear, is it engine knock (rods, crank, lifters) or detonation? Either way need to stop driving and do a complete check and figure it out. Actually first thing I would do is turn the boost down and see if it goes away.
8 87BUICKGNTURBO Member Joined Jun 3, 2014 Jun 8, 2014 #3 I thought it sounded like detonation. How do I turn down the boost?
L larry33kc Well-Known Member Joined Aug 19, 2001 Jun 8, 2014 #4 Do you have a adjustable wastegate. If so the rod will screw out for less boost.
