What will cause an engine to run rich. O2 readings are stuck at .880 and the plugs are black. I've changed MAF sensors, ignition coil and modules and checked for proper idle fuel pressure. I had a Max Effort chip in the car and installed a TT from my DD. Both cars have the stock turbo and injectors. Could a leaking injector or a cracked header cause this problem?
Anyone with a similar problem?
