I have a 87 GN that is having idle problems. I can not remember exactly when this started but for the last couple of months everytime I put the car in neutral or park the engine revs to at least 2500 and just sits there. It will not come down. However if you turn it off in drive, put it in park and crank it, it starts like the choke is on but very quickly returns to normal idle. I want to say this all started when I put a 65mm accufab throttle body on. I wasn't sure if it was closing all the way or not and thought that might be my problem. When the idle is high you can push on the throttle body but it is always closed and the idle doesn't change. I have turbo link and show no codes and it does dectect the park/neutral swtich. The IAC sensor has less than 5K miles on it and I have gone through the reset procedure twice to try to correct this problem. Please give me any suggestions that may help with this problem.
