turbojimmy
Supporting Member
- May 26, 2001
I’m hoping you all can help me think creatively about how to remove my engine with the car sitting on a 4-post lift. I like my lift, but the major drawback is that the car is sitting on a platform 6” off the ground. I can’t get the engine hoist under the car because the lift platform is in the way.
I’d like to pull the engine with the car on the lift so I can simply lift the car up and out of the way while I’m working on the engine. I also want to remove the transmission first which is infinitely easier using the lift. Pulling the engine and trans together is an option but it’s messy and I’d have to do it without the help of the lift.
I guess I can remove the transmission, push the car off the lift, remove the engine, and then push the car back onto the lift but I’m thinking there might be a better way.
First idea is to raise the lift enough so that the hoist will slide under the lift platform. This will put the car about a foot in the air and I doubt the hydraulic cylinder on the hoist will clear the nose of the car at that point.
Second idea is to build some sort of platform in front of the lift platform. The second platform would be the same height as the lift so that I can slide the hoist under the car. I’d also have to build some sort of platform to go between the runways on the lift which would be handy to have anyway.
Last is to hang a hoist from the ceiling. I don’t know how I’d be able to pull this off, but if I could install a beam up there I could hang a chain from it. It’s a standard, residential garage so I don’t know what I’d attach said beam to.
Or I could just forget about the lift and do it in the other bay. But what fun would that be?
Ideas?
Jim
Ideas?
Jim
