I'd contact Jack Laswell and JL Enterprises, 972-412-7280 or 972-412-9000. He's in Rockwall and has probably 8-10 TR's in his shop at any given time. He ships out the machine work locally, but they do plenty of business with him and do it right.
You should also check out Arlington Machine. Lots of the LSBPG (?) use them. That's where I'll be taking the 4.1 block when I have the money. The heads will be done by Ledford Machine in Waco.
If you need hot air work, I can connect you with someone with excellent hot air knowledge in Arlington. Jack in Rowlett is also a great person to have work on your project if you want to stay more local.
Hi Lorenzo, I was wondering where you went. :waive:
the place i heard of was extreme something or another. said they pull the engine and bore it out or upgrade it to a bigger engine. just asking incase i may want another option for work to my car other then the place i bought it from. but i can honestly say i believe i was treated really fair so i may not but it's nice to have options.
Not to hijack, but has anybody heard anything about "Day Custom Engines" in Richardson? Good or bad... Darton recommended them (as local) to dry sleeve an LS-3 block. Most guys on the LS board send their blocks to RED in CA...
