I will try to keep this short in explantation. When I was racing, I made a dumba** mistake. Did my burnout in 2nd gear, when I staged, I did not shift into 3rd. During the pass, it started to cut out and break up. Saw 1.9` of KR so I got out of it. Looked down at the shifter and saw I was in 2nd. On the return I hear a rattle under the hood at about 2000rpms. Did not continue racing. My guess is that I overrevved the motor, I know I hit 84-86mph in th 1/8th, don't know RPMs. Drove the car home, the rattle is fully audible above 2000rpm, but it does not show up as knock on the SM or DS. Pulled both rocker shafts and push rods, did not see any cracks and push rods were straight(both are thicker pieces from Postons). Ran a compression test, all cylinders between 140-150psi. They also built up incrementally. I ruled out a bent valve, but is that accurate. I put a stethoscope to the vavle covers, and don't really here anything. I do hear a tick in the cam sensor and the front cover, just do not know if this is normal. Any suggestions of what to look for, check out or review. Thanks for your help,
