I thought it would be interesting to find out if anyone has found any brand of oil that is not compatible with small street alky injection kits. I've heard and read in the past that you should be careful of some oils that can quickly get attacked by the alcohol in the blowby. The oil manufacturers don't supply a lot of info as far as what alcohol might do to their particular engine oil or suggested change intervals if alcohol fuel is present.
I do know that with a pure alcohol burning engine, a thicker oil is generally used, compared to what might be used if only gasoline fuel was used. The idea is have the reserve protection of the thicker oil available as the alcohol slowly thins and degrades the oil before the next oil change. Which is usually very soon.
I'm wondering:
What oil selection strategies you all are using, taking the alcohol into account?
How often are you changing the oil?
How quickly are you finding the oil become cloudy with how much alky being injected? Single nozzle versus dual nozzle, etc.
Have you found an oil that you must stay away from because of alky incompatibilty?
What weights have you tried and are presently running?
What conditions did you find that forced you to change oil brand, type, weight?
Have some of you found no reason to take special precautions with the engine oil? What brand, type, weight are you using?
I'm wondering:
