I'm experiencing some engine noise in the front of my engine. Does this cam gear look worn enough to make this noise? I recently blew the head gasket pulled engine checked everything out pulled oil pan cleaned it. Bought cometics head gaskets and arp head studs and replaced the old plastic teeth timing gear. Drove it ten miles and started to make this noise. Took the rocker arms off checked them for cracks. Checked push rods, flywheel bolts and converter bolts. Took oil pump a part everything checked out ok.. While oil pan was off also checked the bottom end. Pulled front cover off checked the cam gear it's no more than 3 thousands difference where the chips are on it. Only else haven't checked is pulling cam out.
