Engine Ground
87BuickT
I have a bunch of small braided ground wires from old projects many years ago. Also have a new negative battery cable. Is there a recommended location to use the ground wires? Also, what is the original grounding area for the negative cable? Just want to make sure it's in the right spot......since i'm not the original owner.
The original negative cable went to the bottom screw on the turbo bracket. it really doesn't matter as long as all all the grounds are at secure and at at the same potentail.
ECM grounds went to the back of the head.
Thanks. I see the neg cable. Cant see a cable on the back of the head. Is it a braided cable or regular wire?
