O
Oldsmobuick
Guest
Help! I just failed an emissions test in Rhode Island. Hydrocarbons and Carbon Monoxide are Fine! Oxides of Nitrogen (Nox) are not! 4.05 gpm actual versus allowed 3.20gpm.
1987 Buick GN, stock chip, stock injectors, stock turbo, recent valve job. K&N conical intake, Poston High Flow Catalytic Converter, adjustable fuel reg set at 35 psi.
Car runs smooth, strong, and great. Idle seeks a bit in open loop.
Where do I look?
I am told EGR, and here is what I have done so far.....
There is no knock (detonation) from idle to WOT at this fuel pressure! The motor is soooo strong and smooth!
Tested EGR valve with tester (result ok), cleaned EGR port and installed new gasket. Installed new EGR solenoid.
I do have a concern.... I have 2 vacuum lines open, and no idea where they go? Know where to get a vacuum diagram for the 87?
Any help would be appreciated!
I have 30 days!
Where do I look?
I have 30 days!
