I'm guessing that you're making a drag only car that gets towed to the track?
Read this first...........Is Your Water Pump Costing Power?
Anyone know where I can pick up an electric water pump?
........ As far as cost the fact I can cool my car while in line to make another pass with a flip of a switch is always nice too not always about the horse power.
Because he wants to run an electric water pump??? Really because I've ran an electric water pump for years and I drive my car everywhere and never had an issue, so I'm not sure where this statement is coming from. As far as cost the fact I can cool my car while in line to make another pass with a flip of a switch is always nice too not always about the horse power.
I use these all the time.
EWP115 (12V) ELECTRIC WATER PUMP - PART No: 8025
Basically you have to remove your stock water pump, grind off the vanes and put it back on and it just functions as a drive for your pulley. The electric pump handles all the actual water pumping.
These work super, Ive used them on daily drivers with no problem whatsoever.
We're a dealer for their US based distributor if you decide you want to go with one.
I don't need the stock pump on there for the pulley as I've got a new belt that runs around the crank, alt, and ps. Would I just leave the stock pump in place then and not run a belt to it? And how/where does that pump install at?
No argument there.I believe she is WAY ahead of most of us---Just one little reason she can run the #s--attention to detail!!!!!
I fully agree with this.
I will not in minimize or underestimate your accomplishments, and do not question your desire to maximize efficiencies any way shape or form.
I can also see the reason you run the pump before the run . . . . to cool the engine down as to maximize HP output.
Time to quit drinking or only post when I have enough time to write a decent post. :tongue:.
