does the stock fan supose to run when the car is first cranked up? i always thought that it came on when when it reaches a set temp. if not could a fan sensor be bad?
by that i am assumeing you mean turn it on and not actually cranking it, but turning the key to the on position and pushing the gas pedal to the floor, then the fan itself is not running then. its only on when the car is running.
