My car has a leaking EGR Valve, and has a surging problem with the idle. It will die on me when i put it in gear. I checked for vaccum leaks and found nothing. I bought an EGR Valve from Kragen Auto and replaced it with the correct #27 washer and gasket. I installed it and the problem has gotten worse. I thought that the gasket might of slipped out, so i checked and it was glued fine. What i notice about these local auto EGR's, is that they don't have a button on the bottom of the valve that activates the vaccum diaphram like my original does. I need help guys, any suggestions on this EGR Valve? I have tried 2 of them and both are worse than my leaky original one!
