I have a chip specific for my MAFT Pro so it would have to be able to run off the setup I have. So am I S.O.L on E-85? I am using it as a daily driver until I can buy a 2nd car. However I value performance over mileage. I already only get 10-11 mpg on premium gas. I imagine E-85 would knock it down to 8-9 mpg perhaps.
I would look into why its getting 10-11 MPG. It should be higher than that. That is if your driving normally.If your hammering on the car.. it is what it is.
If you have plenty of gas stations in your area that deal in E-85 and dont mind 2x the fillups.. then its not an issue. Understand the alcohol is a demand system, meaning you dont use it unless in boost. The E85 your burning it 24/7 as long as the engine is running. Expect gas mileage to go .5-.6 of what your getting. So leaving all the same your range will go down 60%. If using as a daily.. you'll be filling up daily. Its bad enough constantly having to fill on E85, looking for stations that deal in it. To me its like having a car that runs on Diesel. You have to find the stations that carry it. On trips your SOL.
Even as a worse case scenario and you got the alcohol system.. you can use it to help cool the charge. There is no downside to using it. You can tune around it where it doesnt hurt anything if you shut it off.
When it comes to performance there is no free ride. This reminds me of when nitrous systems came out.. everyone was like hey $350 kit and make 100 RWHP.. That turned into hurting a motor.. from not monitoring bottle pressure.. then you had the purge, remote opener, bottle blankets/heaters, spare bottle, guages, controllers, timing retards, etc.. that 350 kit turned into 2K.
500 bucks basically you can have a full alky kit added to your car in a few hours and all you need to do is tune it. Its an easy. Dont have to change injectors, dont have to change chips, use the same fuel pump, etc. If your going to be racing the car on weekends, its a toy you dont drive everyday.. your looking for some heavy power.. then you weigh your options. For an 11sec, 12sec car.. no brainer to me. Just my .02
There are plenty of guys that get set in their ways. Even the E85 should be tested. No "Easy" button. If you dont like to test and worry.. leave the car on pump gas and low boost and bypass all this stuff. Once you turn the boost up.. you have to be on top of stuff. Whether testing the alcohol system, or testing the E85 for content. Winter blends are 70%=E70
