HellOnWheels
HellOnWheels
- Feb 3, 2002
FWIW...make sure you replace the stock 15 amp fuse with the correct rated fuse or risk possible major engine damage. I did not do so when I installed the DW400!
After the fp install, and on the first wot test run, boost was around 14-15 #'s when the stock 15 amp fuse blew causing a major lean out EXPLOSION!! Fortunately my engine was still in one piece and still running after replacing the fuse.
According to the paperwork that came with the DW 400 it shows the necessary rated amperage that the pump requires. I read "part" of the paperwork but obviously not all.
HTH
HTH
