I don't think so, but with the current selection of convertors, I don't know how useful one would be. I am speculating, but I don't know that a 2004R could handle the kind of power and large turbos that would make one useful.
You need a 3200 stall ptcNot for that kind of deal. But for my mountain car. Everyone says I need a 3500 stall for my +.020", stock stroke, 9.0/1 comp, ported irons, ported intake, 65 tb and big dog house, big slic, dual 3" exhaust, 3" dp, T/A race headers, 60 lb inj, 320 pump, adjustable regulator, comp 212 .537" roller (1.65 rockers), port plate, tt chip, 62/62 jb turbo, suspension mods, 3.50 geared 9", (because I bought it with a 7 1/2" posi with 2 something gears!), and good tires. I have a 25-2700 stall to go in the fresh, built, 200 r4 trans to put in the car when I install the motor later this month.
No dragstrips here anymore, and I will never install a roll bar!
I talked it over with my old friends at Hughes (local to me), and they figured I might get to 3000 or so stall with a dump, for the occasional street romp.
My other idea is to put a 50-75 hp squeeze kit on it for the launch, with a hobbs switch to shut it off at about 3000 rpm.
The long tube race headers, big exhaust, and high lift/short duration roller cam idea was to make decent torque and mid range before the turbo spooled.
I did not like the last GN I drove with a 3300 unknown brand stall, too loose for my idea of an everyday driver.
Ideas?
TIMINATOR
Your never a bother my friendGood info to know! I THOUGHT that my contact had better info. Thats why I asked on here. He told me the valve would get me 500- 600 stall. Good thing I didnt put my eggs in that basket!
I shoulda just called you. I didnt wanna bother you. My bad. THANKS!
I'm an engine guy, not a trans guy.
TIMINATOR
WOW! THANKS! TIMINATORYour never a bother my friend
Your comment displays extreme arrogance and is extremely condescending.You guys are pissing in the wind
The dump valve is around 150rpm worth of stall.
They are used with high line pressures on certain kind of combos to stop the pressure from trying to push the crank out of the motor,this valve basically bypasses to the case so line pressure cannot exceed a certain psi.
Arrogance is not experienceYour comment displays extreme arrogance and is extremely condescending.
You are waaay out of line telling me I am pissing in the wind.
If I was sensitive, my reply would look like this ^^^^^Arrogance is not experience
unfortunately experience can be taken as condescending over the internet and even in person sometimes.
I dont need to explain myself to you or anybody else.
My comments aren't what you say they are you seems to be very sensitive for some reason
You yourself said you were speculating the effect of dumps.
I dont speculate seen a few them and I was trying to throw the info out there to help others.
Hate seeing guys chase their tail but if you feel you know everything then continue on.
No problem, you did not start anything.As usual, I didn't mean to start a "feces storm", it just kinda happens that way sometimes.
Ya know, I have talked to several convertor builders that I have known, and raced with for 40 years, and have gotten different answers from EVERY ONE OF THEM!
Convertor tech has changed a bunch since I have had my last 2 GNs.
In 86-7, with my first GN, nobody had a turbo specific convertor, so I just got with Hughes (local friends), and discussed it to death. We all had a few ideas, so they cut apart 3 or 4 convertors for me, and keeping good notes, I tried different things, took pics, notes, and they welded them up for me. I tried them all, they cut the best ones apart, and we went further. Since I have a complete engine, and general machineshop, plus a lift, and a then new performance timer, I got enough data for us to work with. They sold that combo as their GN convertor for years.
Then, my roots blown, street and race car and boat period took over for 30 years. Now, I'm back here with another GN, and ignorant all over again.
I THINK that I have a decent engine, driveline, suspension, and exhaust system now. Time will tell.....
On unknown combos, I always start out with a tighter convertor to see what I have with the power band, then I can give good info to the convertor guy. Thats where I am now, assembling stuff.
I just thought I would bounce the dump valve idea off of the brains on here and see what they thought.
Thank you all for your info so far, I'll have more info and questions later.
Meanwhile, I will help others with what I know, and absorb what I don't.
TIMINATOR
