I just bought the dual fan setup from ramchargers without the harness...just the fan assembly...before I used my stock fan and I had it hot-wired to a toggle switch inside the car...I ran two wires off the wiring harness inside the motor compartment where the fan relays used to be...I ran two wires off the power wire (redish pink) and ran one wire to the positive terminal and one wire to the negative terminal on the stock fan...it worked perfectly and I could control my fan whenever I wanted to even with the car off...
well how the heck do you wire the new fan setup like this? Can I cut off the current connector that is on the fan setup and hotwire my two wires I used before into this new fan? I see there are 4 wires in the connector? which color wires do I use for positive and negative???
