L Lorenzo Member Joined Nov 7, 2006 Jan 25, 2010 #1 I have a set of 16" GTA wheel and I would like some one to tell me what is the biggest 16" drag radial that will fit with out cutting the car.
toofastforyou 2FAST4U Joined May 25, 2001 Jan 25, 2010 #2 Lorenzo said: I have a set of 16" GTA wheel and I would like some one to tell me what is the biggest 16" drag radial that will fit with out cutting the car. Click to expand... M&H makes a nice 275-55-16 size drag radial tire...(see picture below) Claude. :wink: P.S: note that in the picture, the rim is 10" wide, but these tires will fit on an 8" wide rim. Hope this helps...
B Brer Rabbit Pursuit Specialist Joined Feb 5, 2005 Jan 25, 2010 #3 I run a 255/50/16 Mickey Thompson. It fits very nice and is 26.2" tall. I think that M&H is 28" tall which is why I went with the Mickey as its the same size as the fronts.
G grocerygetter Active Member Joined Mar 8, 2005 Jan 26, 2010 #4 you can run a 28" tire if you want the gearing change....don't forget a 27" tire does well also. I don't think I want to go back to a 26" after driving on 28s.
R RussellinNC Car lover!!!!!!!!!!! Joined Jul 29, 2001 Jan 26, 2010 #5 toofastforyou said: M&H makes a nice 275-55-16 size drag radial tire...(see picture below) Claude. :wink: P.S: note that in the picture, the rim is 10" wide, but these tires will fit on an 8" wide rim. Hope this helps... Click to expand... Looks good!!! Russ
