Drag Radial Size Question
Marty Q
I want to put BFG Drag Radials on an 87 GN stock rim. What size is the best for street and track use.:confused:
I squeezed a 275 on it but you will have to put a spacer, I had a 7/32" on there could had gone smaller but could not find a smaller one locally. Its you also have aluminum drums this should not be a problem.
hey marty. I run 275 60 15 on convo pro rims 7in wide rims have no prob no spacer either if you run the stock gn rims or tr rims will have to use spacer .
Dang it's close
My 275-50-15's just barely rub on the frame rails, I'm thinking I can cure the rub spots with a big hammer. - BB
275 50 15 nittos on stock GN wheels. I have at least 1/2" on each side. Been on there for 3 years and still going.
I have 275-60/15 BFG DRs on 15x7 TT II wheels and I need a small spacer to keep from rubbing the frame. Backspace is 3 3/4.
Check out the last picture on my website, "click" on it to enlarge it.
Stock rims with 275 50 15 Nitto DRs.
