I did a search but could not find anything.......
I have been running the converter I have for quite some time it is a Art Carr 10" 3000 stall NLU
I have always felt that the car does not leave hard enough and does not spool as fast as it should, I finally have the car running pretty good on the street and that is where it spends 95% of its time. The best pass the car has seen was two years ago and that day was the most track time the car has seen also. It left ok but still feels like it should be leaving much harder and spooling faster.
That pass I left at about 5-6 psi pulled a 1.72 60" it went through at 11.54 @118 this was on 19psi and 26" tires....since then it has been back to track last year got 5 passes before I popped a head gasket.....but every time it left it just seemed to take too long to spool.
I have never thought I had a convereter issue but I am looking into it now, the reason being is I have been playing with E-85 so I can run a lil more boost than usual I actually just got back from a lil drive gave it a few more pounds expecting faster spool and I was wrong. I have been running 15psi and it is slow to spool from a stop even holding 5psi. I gave it 2 turns in 16-17psi and the lag time is virtually the same but obviously making more power.
I spooled it up in the driveway as soon as I saw the needle on the boost gauge just barely move "0" psi I looked at my rpm 1900 that seems awfully low.
stock ported and polished heads larger valve
Old school TE-66
210/215 roller
Stock gearing 26"tires
Do I have a converter problem?
Old school TE-66
210/215 roller
