1LowLeSabre
- Mar 13, 2008
Anyone here running diesel oil? Say 15W40.
Breaking my new engine in on rotella straight 30 it has a roller cam...
But you can run diesel oil 15W40 with ZDDPlus and be ok, correct?
kirban 2 cents worth
ppm would be where it needs to be...the issue is, diesel oil has stuff you don't want in your gas engine for soot control etc....I don't have the tech info handy....
I don;t quite understand why you don't want to use the oil available for gas engines that the car calls for on your visor label...and just ad zddplus...oil is the life line of your engine....just my thoughts....kirban
Is gm eos pretty much the same?? Bought 2 cases 3 years ago.
The newest Rotella, it changed about 2 years ago, has lesss zddp than the old stuff, and more "soot control" additive.
Since it is for diesel use, it is made for low RPM operation, and has lots of detergent for soot control, which you do NOT want in a high performance turbo engine.
