BuickPower3800
Turbo Buick's Rock!!
- Jul 14, 2002
Does any one know what the stock horsepower would be for a 1987 GN? It was rated by the factory at 245, but that number seems a bit low.
No way the engine has 425 ft/lbs torque factory. My TTA dynoed 320hp and 399 ft/lbs torque with a chip, downpipe and no cat. Keep in mind the TTA engines had more factory power than GN engines. Not to mention more boost, different heads, headers, pistons, intercooler and a few other little doo-dads to up power over the 1987 version of the LC2 engine.
Wasn't the factory HP and torque rating at the flywheel? Comparing the TTA and a GN based on a chassis dyno doesn't really do anything in determining what the "real" factory HP and torque numbers were. I always thought GM performance numbers were at the flywheel, not rear wheels.Originally posted by GNSCOTT
The TTA and GN had the same HP with the same boost. The heads are different no better (ask Tom at Champion, he has flown both), neither head can outflow the headers so no gains there, pistons make no more power, (same compression ratios) Intercoolers, I think the TTA's might have had one more row, but the problem with both are the neck, so I don't think the TTA's made it any faster, they just held more air in limbo that couldn't flow out of that bottlenecked, neck. I beleive the TTA is faster due to its extra factory boost, and aerodynamics, and in the case of the GN I beleive a little lighter. I think the Dyno differences of a GN and a TTA on a dyno, both running 16#'s of boost are negligible..JMHO though.
No disagreement there Scott. The old HP numbers were like MPG ratings...Originally posted by GNSCOTT
Art, the problem with GM's #'s are that they lie. GM does do it at the flywheel with all accessories hooked up, so they underrated the GN big time. Now that HP means alot , GM is pretty much on the mark now. The Cobra I think is trying to make up for the 2001 fiasco of overrating the HP by underrating the HP of the 03 Cobra.
I still think that the factory HP #'s of a TTA are closer to 290 HP and a GN running 16 psi would be around the same. You quoted the GN at 275 stock w/ 14 psi and 1# of boost ='s 10hp, so that would put it at 295, and I'd think you would even agree that 6 hp more is negligible.
Then why will a TTA WASTE a GN at the track if both are factory stock running 16psi? Aerodynamics? Doubtful that it makes that large of a difference.Originally posted by GNSCOTT
Everyone always talks about the Flow of the GN and TTA heads, what about the design? Take a look at them, they are TOTALLY different. Did anyone ever think that maybe the different design of the TTA heads allows them to make more power????
