Over the last month, I replaced/installed the following;
Duttweiler neck stock intercooler
AlkyControl Single nozzle(havent used it yet)
RJC Power plate for Kenne Bell intakes
New coil module and coilpack(old one wasnt bad but was sputtering with it after mods)
New 160 degree thermostat and billet t-stat pipe
New Felpro 9441HT Head gaskets(not blown, preventive maintenance)
New Felpro 1000 intake gasket set
Copper exhaust gaskets and turbo gasket.
Ever since I got the car running, it has been running hot. I havent given it the chance to go over 215 degrees but it will sure as hell get hotter than that. I cant seem to drive it more than 3 miles w/o it running hot. I checked my electric fan, is correctly pulling air through the radiator and blowing on the engine, I even set it up to run with key on, engine off. I havent gotten a chance to get into boost because of the conditions Im having.
It also has a part throttle sputter/miss/stumble kinda feel to it. didnt have this before the mods. If I throttle past the stumble, it seems to run fine but havent got a chance to run it much due to the coolant!
HELP!!!!!
Chris!
HELP!!!!!
Chris!
