T
THE RAVEN
Guest
We are posting this for a friend of ours...We are experiencing difficulty in installing a DFI into a car with a digital dash. We purchased a three bar map sensor already. Although the car idles fine with the DFI computer, it is unable to build boost (the car does not respond to the throttle). The car runs perfectly with the stock computer set up and is able to run 25 psi of boost without any problems. The map sensor connection is hooked up by the middle wire from the mass air flow sensor, and the two wires from the TPS. Are there any other connections that we need to make? And also, how are you able to distinguish between a Batch Fire DFI computer and a Sequential DFI computer? Does the Sequential DFI require any additional modifications? (The DFI and the injectors, came out of another car.) T.I.A.
THE RAVEN.
THE RAVEN.
