just plain john
El Camino a Go-Go!
- Feb 24, 2007
Ok, so I'm making a push to get by build finished. I've swapped a GN dash and harness into my El. I sourced these components from different sources, and I saw neither come apart, so I'm having to wing it. First up, the headligh and dimmer switches and connectors. Pic 1 shows the maximum width I have to install the connector, and pic 2 illustrates how buch taller the connector is. Pic 3 shows the top 'slot' that is supposed to ride in the edge of the top and bottom of the hole, I think. If I insert either end of the slot into the hole, the opposing edge of the connector still doesn't clear. I've tried a few things, but I cant get the seated into the hole. I tried putting the switch in the dash and sliding the connector over it, but there's nothing to retain it and it just pulls off so I don't think that's right. Surely someone has installed a dash, did you have the same problem?
