Had my engine rebuilt no leaks...except for that darn oil tee. Tried a new fitting threaded in 2/3 way in and tight! Threads look fine on both surfaces. Dry for a couple minutes then a small drop appears. Began again by recleaning mating threads with some pipe dope. Same result.
Should I try some teflon tape or give me a clue of what would work.
Finally have the GN running well but hate leaks.
This is a job for...ta-tata-da the turbo Buick gurus.
Thanks, Charlie
Thanks, Charlie
