T trivownr New Member Joined Apr 11, 2007 Sep 25, 2014 #1 I need a new Crankshaft Positioning Sensor for my 85--no spark or injector pulse. I pulled one from a parts car. Is there a trick to installing it, or is it straightforward?
T Toby_Goodmk Test Fit officianto Joined Dec 9, 2011 Sep 25, 2014 #2 width of a credit card spacing from the reluctor wheel
V v6turbo87 Active Member Joined Mar 27, 2014 Sep 25, 2014 #3 Rotate the engine by hand while you are under there and make sure the spacing of the reluctor ring is even for a full rotation.
N NorCalTurbos Slowing down to SPEED UP!!! Joined Nov 9, 2013 Sep 25, 2014 #4 Disconnect the battery then follow above instructions you should be fine
L luisturbog UNDERDOG HOT AIR !!!!!!! Joined Mar 30, 2007 Sep 27, 2014 #5 Toby_Goodmk said: width of a credit card spacing from the reluctor wheel Click to expand... X2 I cut up & used an old credit card, Worked great! I updated to the new crank sensor though.
T trivownr New Member Joined Apr 11, 2007 Sep 30, 2014 #6 Thanks guys. Hoping to install the "new one" next weekend.
