T TurboBusa huh?? Joined Jun 16, 2004 Aug 15, 2009 #1 does anyone know the crank sensor supply wire volts? how do you properly set the crank sensor when using a fluid damper its pretty tight and it seems to cut into the plastic of the sensor? any one run into this problem when using different balancer?
