Guys,
Could some one please explain to me the proper way to setup the Crank Reference angle and Ignition timing for a FAST/SFI module? I have been told that all that really matters is that the timing idle retard be zero'd/disabiled and that the light agrees with the ECM. But I suspect there is more to it than that.
Also,
I believe I may be having a Rotor Phase problem that is causing eronous timing readings and spark scatter.
I am using an MSD ignition that has both the Cam Sync and Magnetic outputs from the reluctor since I don't have room for a Crank trigger.
Doug
375CI Twin Turbo (1008HP at The Crank/w Ignition Problems)
Also,
Doug
