If they are scratched debris went through them and is probably embedded in them. If the debris is still in the engine it will do the same thing again. Bearings are not wear items.
started car with 20-50 weight oil pressure held good till over heat from blown top rad hose, oil pressure then oil presure went to hell 0-2,3 @ 200 degrees.
