i've had this problem for awhile now. when the converter locks up at interstate speeds only and you are barely on the gas, just trying to maintain a steady speed, there is alot of shuddering-shaking going on. if you give it gas, it seems to pull and hold ok. seems to be locking and unlocking ok. my fuel map is smooth in the area it is occuring. seems to be worse the longer the car has been driven w/lock up on. unlock the converter and the problem goes away.
i've been told that it is probably the lockup disc. and that may be, but is there any chance it could be the solinoid, or something else? before i get the converter out and cut open. anything or anyway to get a perfect diagnosis of problem first?
