ok well im reposting this with way more information and pic's, hope it helps.
first and foremost i am not a mechanic although i do my best, everthing i know i know from you guys many thanks
alright well i just got done putting her back together and ready to take her out for the test drive when i notice the temp guage wasnt working
here is powerlogger and pic of guage
out of pic space sorry it was just a guage
so after a quick post i started diagnosing with vortexbuicks fan trouble shooting guide and this what ive done
first i was able to get them to work by turning on the a/c no problem then i went to the delay switch
and no problems while i was at switches i pulled what i think is the a/c compressor switch connector and ground it i got nothing??? but it worked when i turned on the a/c
then the delay relay i figured was good so i didnt really mess with it
after that the hispeed and lowspeed relays refer pics for what i did
so pretty much all checked out good
so does this mean that i have a bad ecm?? it is reading the correct temp to powerlogger
and i dont see how the fans are connected to the temp guage not working
any advice is greatly appreciated
now for the work i just completed oil pan gasket, driverside motor mount, timing chain and gears, and oil pump spring.
TIA you guys have been great
