Well i found the source of the problem. Its my VSS (vehicle speed sensor). Now my problem is i have no idea where it is located. Can someone help me out with locating it? Thanks in advance.
First check to see if the connector on the buffer box is plugged in all the way. It's located under the dash just to the right of the steering column. It's rare the VSS sensor goes bad but is possible. If you have to pull it you just have to pull the speedo cluster which bolts in from the front.
