Thanks!!! Glad that i could help. What did you end up running last night. Let me know when you go out there again.Originally posted by brn agn
Congrats Rob! I saw two of your runs and the car looked great going down the track. I hope you get it sorted out, that car is going to fly!
BTW, remember last summer when you told me to ditch the Thrasher chip? I took your advice and put the stock chip back in for last night (and fixed a lot of little problems). The car picked up a full second in the 1/4! Thanks!
That sucks that rear let go. I seen you on the side of the highway and i new something was wrong while i was in the pits.Originally posted by brn agn
My best run was 13.08 @104mph. I wanted a 12 second pass really bad, but it just didn't happen. I did manage to break the rear end in the car. The ring and pinion are toast. I doubt I will be back at the track this year. I will get the car back together over the winter.
I am sure you already checked this, but I have a Casper's Coilpack/Ignition Module Tester if you ever need to borrow it. In fact, I will be driving by Granite City this Friday.
On tuesday nights its the street car shoot out. If you got some DOT tires come on out there and lets what it runs. By the way, everytime i seen your car run it was around 11.70s at about 112 to 115 mph. My car would of went alot faster, BUT it was sputtering all the way down the track on all 3 passes that i ran.Originally posted by 11.20n1320
What record at Gateway???? I have run a best of 11.20 on a stock long block.With atleast 1300 passes on the original motor!YOU NEW THIS WOULD RUFFLE MY FEATHERS.Also I did this on a 12inch. convertor with a 1.51 short time!!
DDay
http://www.stlsr.com/forums/showthread.php?t=40059Originally posted by 11.20n1320
DDay
